Zoominator - Source Zoom and Mouse Follow Plugin
Zoominator - Source Zoom and Mouse Follow Plugin 2.0.5
MMLTech updated Zoominator - Source Zoom and Mouse Follow Plugin with a new update entry:
Zoominator v2.0.2 Changelog (2026-08-09 to 2026-08-11)
- Fixed zoom framing for rotated scene items, rotated sources were pushed off-canvas during zoom
- Fixed stuttering zoom caused by suppressed scale writes
- Fixed cursor-following zoom incorrectly reacting to cursor movement when Follow Mouse is disabled
- Changed zoom updates to drive off the video tick instead of a 16ms QTimer, for smoother playback
Zoominator 2.0.3
- Added three zoom anchor modes: canvas center, fixed cursor position, and continuous cursor following.
- Added smooth mouse-wheel zoom control for Linux X11, with adjustable sensitivity and zoom limits.
- Improved zoom positioning for more natural cursor-focused movement.
- Fixed custom hotkey modifiers not being saved correctly.
- Added an optional support link to the Target tab.
Zoominator 2.0.4
- Fixed the click halo not appearing during active zoom.
- Added an optional “Show halo when not zoomed” setting for displaying click halos outside an active zoom.
- Improved click-halo positioning and reliability during zoom animations.
- Added clearer descriptions for the click-halo settings.
- Fixed all missing translations using LocaleSync
Hi MMLTECH
Thank you for all you do! Unfortunately I am having an issue with Version 2.0.5. The window to set it up comes out with all the options like target, trigger etc.., but can't resize it. I'm assuming at the bottom I would save or apply, but can't see it. Thanks.
