Zoominator - Source Zoom and Mouse Follow Plugin
Zoominator - Source Zoom and Mouse Follow Plugin 2.0.5
but it was anightmare to code that
I see and understand.
But there is another one - the normal zoom + follow does not respect if I crop the source, lets say I have my Display Capture source from monitor 1928x1080, but i have cropped it to inner area to 1280x720 (for smaller output video) but zoominator zooms+follows over the whole original source. The result is that i cannot properly zoom+follow to some corners of the actual target. Is it possible to somehow adjust that?
The source:
and the filter on it (Crop:
The source:
There’s a lot mathematics involved there I’ll have to check if I can get the cropped area as new bounding box
I have multiple monitors and multiple capture sources for gaming so keep them in a separate scene in a group .
Do you have any plans on having this plugin work with nested scenes and groups?
A suggestion would to reset the transform of the source if the source is changed in the tool or dock while it is currently zoomed into on a source. . Find it doesn't recognize the next time you select it and will zoom in more .
That's a bit more complicated, I'll have to change the entire logic from capturing the mouse in the selected source to capturing the mouse in the curent window and that will cause issues if you have different size/resolution screens. Not impossible but is hella much work to do, maybe during the future updates.
MMLTech updated Zoominator - Source Zoom and Mouse Follow Plugin with a new update entry:
Core update
  • Linux X11 support implemented by @derekross
  • Introduced a new mouse-click highlight feature with a configurable halo indicator
  • Added support for directional modifier key combinations (split function keys)
  • Refactored zoom behavior to operate on the entire scene rather than a single source, enabling consistent zooming across all scene elements and source types
Hotfixes
  • Architected New Tabbed Dialog Interface: Refactored the settings UI into a clean, tabbed layout. Global settings are now housed in the "Settings" tab, while source-specific controls live in the new "Sources" tab.
  • Implemented Source Exclusion Filtering: Added the ability to manually exclude specific sources from the zoom logic. Excluded sources are silently skipped during scene enumeration, preventing the zoom anchor from snapping to unwanted background elements or overlays...
Hi, I'm having an issue with your link to your latest Zoominator update. My eyes for some reason are really sensitive to any white background, so it's hard to read. When I do read it I don't see where to download Zoominator. Probably just me. Sorry. Thanks....Update: I went a different way and found it. Thanks.
Wow! You even can check and uncheck sources. Thank you!
Great update!!
Minor issue: My hotkey Iam using is Ctrl+Alt+Shift+F1 and every time I hit Apply a change in the Zoominator settings, my hotkey suddenly stops working. After reopen the settings I can see its been defaulted to F1, in the Trigger Tab. I have to reassign it every time.
v1.9.4
  • Fixed OBS crash on shutdown caused by plugin cleanup touching scene/source objects too late.
  • Added safer zoom recovery logic after unexpected OBS close or crash.
  • Improved protection against sources staying zoomed, resized, or misplaced after relaunch.
  • Updated transform saving so source positions/sizes stay synced with user edits during normal use.
  • Optimized mouse-follow zoom behavior to reduce lag and unnecessary transform updates.
  • Reduced plugin activity during OBS...
Add locales, refactor hooks, timing, and installs
Add full i18n support (en-US filled plus new de/es/fr/it/pt-BR/pt-PT/zh-CN .ini files) and wire UI strings to obs_module_text. Update Windows CMake install destinations to obs-plugins/64bit and install data under data/obs-plugins/${target}. Refactor controller behavior: reduce tick interval to 16ms with a PreciseTimer, re-schedule startup singleShots, and simplify mouse-follow smoothing/anchor math. Replace excludedSources with includedSources (load/save/enumeration updated), add...
You are missing the locales(translation) from data/obs-plugins/zoominator/locale/** if you are on mac, just get them from the windows zip i think i forgot to package them for linux and macos
I have windows. Where does locales folder go in the obs directory?
Improvements
  • Added “Keep cursor centered until the capture reaches an edge,” mapping ultrawide monitors to actual captured-content bounds instead of the OBS canvas.
  • Added configurable “Pause following after idle” from 0–60000 ms; 0 disables it. Movement resumes tracking.
  • Removed continuous halo tracking. The halo is now click-only, improving accuracy and reducing overhead.
  • Added native Wayland detection, preventing misleading XInput2 initialization and invalid (0,0) cursor tracking...
Hello! I hope you're having a good day so far. I've been scratching my head getting this to work. I've put the files in the right directories but it just does not work for me unfortunately. I've put the "locale" folder in obs-studio > data > obs-plugins and the .dll in the obs-studio > obs-plugins > 64 bit and still nothing. Please help if you have the time.
