Stream Deck - OBS Studio Linux Plugin 2.0 v.5.5.4.2
Stream Deck - OBS Studio Linux Plugin 2.0 v.5.5.4.2 5.5.2.2b
LinuxGamesTV
LinuxGamesTV submitted a new resource:
Stream Deck - OBS Studio Linux Plugin 2.0 v.5.5.2.2 - Streamdeck Plugin for OBS Linux
You have a Streamdeck and you want use opendeck with the Elgato OBS Plugin from the Elgato Marketplace?
You get the circle of death with the Elgato OBS Plugin in opendeck?
Thats because the Stream Deck - OBS Studio Plugin 2.0 is missing in the OBS Studio Linux build.
This Plugin solve it. Now you can use the Elgato OBS Plugin in opendeck without the circle of death.
No Flatpak version yet
Testet only with 32.1.1
I've installed everything, and have OpenDeck set up. However, the plugin window for OBS says "SDNotConnected" when looking for the plugin via OpenDeck. This happens with the OBS plugin for both the native install and Flatpak versions of OBS. I have had OpenDeck launched first. Just wondering if there was something I'm missing. OpenDeck is the native install version for me.
Do you have install the Elgato OBS Plugin in opendeck? You need the OBS Studio Plugin 2.2.4 from the Elgato Marketplace
I cannot get OBS Studio 32.1.2 (deb package) on Linux Mint 22.3 to see this plugin period. I've followed the instructions exactly, and verified that the libStreamDeckPlugin.so file exists in /usr/lib/obs-plugins, but the "Elgato Stream Deck" entry never shows up in the Tools menu nor in the Plugin Manager window. The OBS logs don't contain any mention of seeing or even attempting to load the plugin either. Any suggestions?
