Exeldro
Active Member
Exeldro submitted a new resource:
Source Record - Record a source using a filter
add replay buffer option
Adding Record Mode option
Yes it can, just tested it right now, however it doesn't yet record the audio.Can this be used for recording scenes too?
Correct, you can use the source file in Post Production, i believe that is the idea behind it.I am using OBS to facilitate creating video tutorials with as much as possible being done live, so hopefully a practiced Subject Matter Expert can create a finished tutorial video in real time. (the scenes are fully titled and branded.)
But this sounds like source recordings also being record can make much easier to fix mistakes by taking the content into a non-linear video editor — is this correct?
@ASchneider I have only been able to test x264 encoding and have nvenc test planned for later this week.
In the log I see an encoder error: "height not divisible by 2 (256x133)"
Can you try with an other source of which the height is dividable by 2 or add a crop/pad filter of 1 pixel?
Hi Schneider, did you by any chance install the 2019 redistributable and restart your pc?Just did that, and it did not work.
If use FFMPEG (Hardware), it starts recording all sources but OBS crashes after a few seconds.
If I set the exact same settings as my main encoder (H264 NVENC) it does not crash but sources are not recorded.
I'm sending both logs when it crashes and when no files were recorded.
Thanks!
Exeldro updated Source Record with a new update entry:
Version 0.1.1
