Source Clone
Source Clone 0.2.3
Hey Exeldro, I just updated to the latest version and unfortunately none of my existing Source Clone sources work anymore. I'm going to try rolling back to 2.1, but let me know if there's anything I can provide to help troubleshoot.
Edit: 2.1 did fix it for me.
All of my source clones are cloning scenes. A few of them are nested clones (clones of clones), but even the first clone isn't working so I don't think nesting is the issue.
I don't have any that are currently working, but if you'd like I could try updating again and creating a clone of a source instead of a scene to see if that works.
Ok, I updated again and tried messing around with it. Here's what I found!
Creating a new Source Clone of anything works fine without any issues. So the problem for me is only existing Source Clones (which I only have of scenes).
Going into the Properties of any broken Source Clone and changing a setting doesn't do anything. If I click "OK" to close the properties, the Source Clones remain borken.
However, if I simply open the Properties and click "Cancel", the Source Clone fixes itself! I went through and tried it with every one of my Source Clones, and it worked with all of them.
Unfortunately, closing OBS and relaunching it breaks them all again, but the new ones all remain working.
Essentially, this newest update isn't really backwards compatible without some effort. To avoid issues, I would need to recreate all of my Source Clones.
Hope this helps! For now I'm going to roll back again, but let me know if you want me to give anything else a try.
Thanks!
Hey Exeldro,
Sorry for the delayed reply! It's been a busy week...
So I had an odd thing happen. I updated back to 2.3 and then tried to duplicate my scene collection to cut it down to one of the source clones for a json export, but this caused OBS to crash:
When I restarted OBS, it was on an empty new scene collection. Switching back to my regular scene collection, all of the source clones are now working even after restarting again.
Trying to duplicate it again crashes it still, so I'm not sure what's going on there, but the source clone issue seems to be fixed now?
If you want I can send you the full json export, but I'd hate to waste your time if this was just a weird isolated quirk I was experiencing after all this. Sorry for taking up your time!
Thanks
I need help with the installation. I've tried both installing it manually and with the installer, as well as various versions but it doesn't work. The files are all on their respective place but the "source clone" option doesn't show up when adding a new source.
Hey Exeldro, I am not sure if this got answered somewhere, so sorry in advance.
There is a problem if I use your "Source Clone" plugin (ver. 0.2.3) in combination with your "Move" plugin (ver. 3.2.1).
Steps for reproduction:
The movement of one source from Scene A is not mirrored (cloned) in Scene B.
create "Scene A":
- create a "group" folder with a random picture inside
- insert two "Move Source" filters on the "group" folder -> rename them "shrink" and "expand"
- on the filter "shrink" change following filter settings: "scale: x 0.500 y 0.500"
- on the filter "expand" change following filter settings: "scale: x 1.000 y 1.000"
- hit "shrink" -> picture is shrinking, hit "expand" picture is expanding to its original size
create "Scene B":
- create a "clone source" and clone the "group" folder (from Scene A) -> the picture should be visibile now
go back to "Scene A"
- open the filter settings on the "group" folder and keep it opened
click back on "Scene B"
- hit the "shrink" filter -> nothing happens with the picture (same if you hit the "expand" filter)
The movement change ("shrinking" of the picture) is only visible on Scene A. Once the pictures has changed it is visible on Scene B too. But the change won't be visible if you are already on Scene B.
The "Move" filter in combination with the Source Clone plugin is only working fine outside of a "group" folder if you put the filter directly on the scene.
Am I missing something or is that a bug with grouped items?
i have problem with source clone @Exeldro :
i have 2 obs instances1st obs (stream) https://obsproject.com/logs/KdntmrhXc9IFRiPe
2nd (recording obs to be able to turn on/off delay on stream obs) https://obsproject.com/logs/ODAWb7z4N4CY9NHc
i setup streamerBot to switching scenes: Desktop→DelayStart (20sec (adjustable delay time]→Delayed (.mkv video which is recording on 2nd obs and runing on 1st with delay
but my main (1st Stream obs) isnt releasing for some reason game capture so my 2nd obs cant capture it (you can see in logs its pinging it and cant capture because 1st obs isnt releasing it (because of Source clone (im 1000% sure its because of it, i spend 3 days to found it and today i finally did (but it was working fine before somehow and i cant understand, why its stopped (i didnt change anything i think, now its stably not working 100% of time)
and what i found too that if i will readd source clone game capture its start releasing game and i able to switch, but its working before next launch of obses (if u need some more info i can tell here or we can have video call in Discord i will show all in it)
ok, i have an update, version 0.2.3+0.2.2 is not working version 0.2.1, 0.2.0 and 0.1.5 is working good and game capture is stopping as it should be (obses versions 32.1.2)
I'm not sure if I did something wrong, maybe it is even unrelated to Souce Clone, but...
I did a cloned source of a scene, as I wanted the scene to be of the games I played. Mainly through a capture card, but not always.
I set it to have the video and audio as separate sources, because for some reason setting the sound to come from the capture card itself makes the sound bugged but setting it from an audio source makes it sound fine.
The idea was that, putting the scene as a source clone, I could give it the audio filters for all game sources in a single place, especially the sidechaining.
The problem is, when they are separated sources the sound does not seem to go to the cloned scene source. When the sound comes from the same source as the capture card it works, but with the audio coming from a different source the cloned scene makes no sound.
Putting the scene itself as a source gives it the proper sounds, though (although as separate sound sources in the audio docker, instead of a single one like cloned scene source does).
I'm not sure if I'm explaining it properly...
