Smart Lower Thirds
Smart Lower Thirds 1.2
The functionality is excellent, but I would like to suggest an improvement. There is a keyboard shortcut option; in my case, I use StreamDeck to facilitate function transitions. I checked and realized that this feature is no longer available. Please check if it's possible to enable this function; using StreamDeck to transition between lower thirds would be much more practical and faster.
The control panel approach looks very practical for live productions where operators need to update names, titles, and branding quickly without touching OBS scenes directly.
One thing we've noticed from working with live graphics is that flexibility is often just as important as design. Features like font customization, logo support, remote control, and quick updates can save a lot of time during live streams, interviews, sports broadcasts, and podcasts.
It's also encouraging to see active development and regular feature updates based on community feedback. Tools that simplify graphics management help creators focus more on content and less on technical setup.
Thanks for sharing this with the OBS community. We're looking forward to seeing future updates and enhancements.
This is a great tool. I am planning to use it. But the only suggestion for improvement is :
The global settings do not have an option to change the colours, Logo for each of the lower thirds. If I have to display 10 names for an event and have to change the logos for another event, I cannot change the logos/colour scheme at once. The Advanced settings in Global Settings may have all the settings for individual lower thirds except the name and title to improve the convenience. But apart from this, it is a great tool. Or when we create a lower third, we can have an option to copy a LT (Lower Third) to keep the colour/Logo options.
Resequencing option would be better as after finalising the LTs, we might have some missing sequence numbers for LT IDs, resequencing button would start the IDs from 1 to Max. LTs.
