Scoreboard Overlay and Controller Plugin
Free Scoreboard Overlay and Controller Plugin 5.0.1
MMLTech updated Fly Scoreboard with a new update entry:
Introduce formatting toolchain and CI checks and added WebSocket/server wiring.
Adds a reusable formatting framework: .run-format.zsh, small formatter wrappers (build-aux/run-*) and helper logging functions, plus composite GitHub actions (run-clang-format, run-gersemi) and a check-format workflow that is invoked from PR and push workflows. Updates PowerShell Windows scripts (Build-Windows.ps1, Package-Windows.ps1) to simplify logic, load utility functions, improve error checks, and produce a ZIP staged with the OBS plugin layout. CMake updated to link Qt Network and...
Thanks for creating this tool. Could you add the functionality for tracking a score which consists of two elements rather than just a single element, i.e., when a score consists of Goals & Points? For example : Team A: 1:10, Team B: 2:05 (where 1 & 2 are Goals and 10 & 05 are Points)?
That can be done creating 2 scores and wiring them in the html
Thanks for the reply. If only I was able to "wire them in the html" :). Could you enlighten or help me in doing that? Much appreciated!
MMLTech updated Scoreboard Overlay and Controller Plugin with a new update entry:
Fly Scoreboard 5.0.0
Fly Scoreboard 5.0 is a major update focused on modular sports graphics, simpler control, and a clearer setup experience.
Important changes before updating
  • - Fly Scoreboard no longer creates, selects, renames, resizes, or changes OBS Browser Sources.
  • - Existing OBS sources remain under your control. Add each HTML panel manually as a local-file Browser Source and arrange it directly in the OBS preview.
  • - Templates must be copied to a location where OBS can read and...
