Remote OBS via Virtual Private Server (VPS)?
SnazzyFPS
Howdy!
I have streamer bot on a different network running Windows Server. Is there a way to get my OBS and my Chatbot hosted on the server to talk to each other?
I have been playing around with ZeroTier and Tailscale but unable to connect both machines (did indeed do port and allow 4455 port etc)
Anyone happen to have experience with ZeroTier/Tailscale or any similar alternative?
Thank you.
You should contact streamer bot support directly.
Wasn't much they could do as Streamer.bot connects to OBS without any issues and is fine.
It's more getting two systems to connect via obs's websocket. I'm assuming its Firewall or something stopping them talking to each other so considered ZeroTier/Tailscale to do this in a safer way but no luck so far.
I had a similar setup before and ran into some weird latency issues until I switched to using a vpn service. Once I connected both the VPS and my local system through the same vpn service, I got a much more stable and faster remote connection. It also helped with port forwarding since I didn’t want to mess with the firewall settings on the VPS too much.
I'd start with Tailscale- its usually simpler for this setup.
Make sure:
Both devices are connected to the same Tailscale network
OBS Websocket is enabled and not bound to 127.0.0.1 only
You're connecting to the Tailscale IP on port 4455
Windows Firewall isn't blocking the connections.
If it still doesn't work what the exact error- timeout or connection refused?
