PTZ Controls
PTZ Controls 0.19.2
Hi glikely, (love your plugin) I was wondering if this went any further?
I'd love to able to have ptZ controls change camera preset when switching to a different scene...and the camera automatically moves to the appropriate preset position... is it even possible? (using advanced scene switcher)
Thanks in advance for any reply... bravo.
I think this is already implemented. You can attach a PTZ action to a scene already. When you change scenes the PTZ action is called...
OMG I can't beleive I didn't know that, thanks so much... really hope the plugin gets the needed update, such a shame that the OBS one messed with it.
Although, maybe I would have been ignorant for all time, if it hadn't.
This morning I opened obs and the ptz plugin appeared in obs failed to load and was missing from the dock, please provide a solution and update this ptz plugin.
Hello, I use the MOVE plugin.
I can add filters within the scene. This way, the camera moves automatically every time I select the scene; it moves to the settings defined for each scene.
Esta manhã, ao abrir o OBS, o plugin PTZ apareceu, mas não carregou e desapareceu do dock. Por favor, forneçam uma solução e atualizem este plugin PTZ.
Como eu uso muito esse plugin, a solução que encontrei foi voltar o OBS na versão anterior até eles solucionarem, só não se esqueça de fazer um backup das configurações e do(s) perfil(s)
I too am having issues with this as a new windows 10 pro machine reload and the tools say its loaded but does not show up in the docks
OBS 32.2.1
PTZ Camera Control for OBS v0.18.3-rc1
Now it shows 2 obs-ptz entries in the failed window
Error:
The following OBS plugins failed to load
obs-ptz
obs-ptz
Please update or remove these plug ins
Faça um backup do perfil e das configurações no seu OBS, e faça um "downgrade" na versão do programa. Eu consegui resolver assim o meu.
We rely on this on a daily basis, so grateful for it. The sooner it's fixed, the better.
Thanks for all the efforts on this.
Hello @glikely (or whoever is supporting this plugin): In case you haven't seen it already, we have been offered this assessment of the issue that several users are reporting, where PTZ Controls is not loading with OBS Studio 32.2.1:
"It looks like the developer is distributing non-standard Qt components (Qt6SerialPort), this will always be a risk as OBS is free to update its Qt version at any time, plugins are not supposed to depend on it. If the developer has abandoned the plugin, finding a 6.11.1 compatible version of Qt6SerialPort might work around it."
Can you please comment.
Thanks. . .
Hopefully very soon! I had to revert to an OBS/PTZ Optics( forget the version as I am not at the site) controller software that is horrible but I need to change the pictures as our church uses different angles for serv ices ! Thx for the updates !
Good Morning! Do we know of any progress for the plugin ? Tryiong to use the site controller but it is not cooperating when trying to chan ge scenes and camera angles etc. Thx
