OBS refuses to use AMD h.264 encoder
cowkiee
I have a laptop with ryzen 7535s with rx 6550m, and I've already updated all my drivers, but obs wont let me use the h264 encoder. using the x264 sucks, so i would prefer if I could use the hardware encoder instead. here's the log file, I notice this popping up always:
[texture-amf-h264] amf_avc_create_texencode: Wrong adapter
anybody know the fix to this? I have the log file attached
Not sure if this is the fix but make sure OBS is running on the High Performance GPU:
Open Settings and search for "Graphics Settings". Select "Classic App" and browse to C:\Program Files\obs-studio\bin\64bit\obs64.exe (or wherever you have installed OBS). Click "Options" (example screenshot).
This may prevent you from using Display Capture.
yeah, no luck. still the same error
hey, i have the exact same laptop and the same problem as well, but when i tried to put obs64.exe on high priority on graphics settings, and restarted my computer, it doesnt work. I also updated my gpu driver
i have tried every solution under the sun e.g disabling igpu, putting obs on my high performance gpu, run as admin, etc etc it does not work and i have the same exact laptop
i have tried every solution under the sun e.g disabling igpu, putting obs on my high performance gpu, run as admin, etc etc it does not work and i have the same exact laptop playfy
Hey, I have the exact same laptop and the same issue, however it doesn't work when I try to restart my machine and set obs64.exe to high priority in the graphics options. I upgraded my GPU driver as well.
