Need help with Aitum Multistream plugin
TheDonberry
I've used the plugin successfully for a while now, however as I'm trying to increase the amount of platforms I stream to, I think my secondeary PC is reaching its limit. My question is, is there a way for me to stream to 6-8 platforms? If I am generating the same exact stream from Twitch, to Kick, to Youtube, is my GPU encoding literally a whole seperate stream, or is there a way to lighten the workload? My guess is it has to generate an entirely new stream, using up resouces. Second question: often times my sources in OBS will freeze. My capture card video source, and my camera source. I can fix it by deactivating and then activating the sources usually. Why does this happen? I've updated drivers and checked that my cables correct.
Specs:
Streaming PC:
3070 GPU 8 GB
Ryzen 5 5500 GT
RAM: 32 GB
64bit OS, X64 processor
Internet:
Ethernet
Upload Speed: 41.9
If you have issues with a third party plugin you should contact its dev (and other users) via the Discussion section on the particular plugins' page or wherever the dev have set for this.
