Hello,
I'm hoping someone can help me recover an important recording that cannot be recreated.
System
I recorded a once-in-a-lifetime event. When I clicked Stop Recording, OBS became stuck on "Stopping Recording" for approximately 35 minutes.
During that time:
The problem
The recording appears to be corrupted.
After switching to the Apple VT H.264 Hardware Encoder and changing my recording settings, all new recordings work correctly, so the issue seems limited to recordings made with my previous configuration.
Relevant log information
The log includes:
What I still have
I can give a small sample of the damage MKV if needed.
Thank you.
System
- MacBook Pro 13-inch (M1, 2020)
- macOS 26.5.2
- OBS Studio 32.1.2 (Intel version, running under Rosetta)
- Recording format: MKV
- Video encoder: x264
- Audio encoder: FFmpeg AAC
- Rate Control: CBR
- Bitrate: 6000 Kbps
- Output Resolution: 1644×1028
- 60 FPS
During that time:
- The recording file continued to exist on disk.
- The file eventually grew to about 2.48 GB.
- OBS eventually returned to normal without crashing.
The problem
- The timeline originally showed about 58 minutes.
- The video is almost completely frozen from the beginning (only a few frame changes).
- The audio becomes corrupted around 24 minutes.
- Remuxing the MKV to MP4 does not fix it.
- VLC shows the same behavior.
- Playing the MKV directly in OBS also shows the same behavior.
The log includes:
- <span>Rosetta translation used: true</span>
- <span>Video stopped, number of skipped frames due to encoding lag: 190098/190144 (100.0%)</span>
What I still have
- The original MKV file
- A remuxed MP4
- The complete OBS log from the recording session
- Does the log suggest the encoded video frames were never written, or could the MKV still contain recoverable video data?
- Is there any recommended recovery method beyond remuxing (OBS tools, FFmpeg, or another approach)?
- Has anyone seen this specific combination of symptoms before (Intel OBS under Rosetta, recording stuck on "Stopping Recording," and 100% encoding lag)?
- If needed, I'm willing to provide the log file or a sample of the recording.
Thank you.
