NDI HX capture || help settings
sammieko
Member
Helloo fellasss i need some help with my NDI screen capture. I’ve recently purchased this application:
And i have to say it works
Great in compare with every other app i tryed.
got only one question now. Does someone knows how to lower the resolution and ive possible maybe the fps.
Like when i receive the screen capture on my laptop, its in 1080p 60fps. Can i simply make this like:
720 60fps or 720 30Fps?
how do i do this, or can this be set intro the iphone record settings ?
someone with more brains from it all then
This rookie wich can give me a clear answer
greaaaatzzz,
Sam
what do you mean free? I’ve had a couple of other applications where i tryed out streaming through my network with, but they didn’t satisfy my wishes.. i knew this app whas there, and i decided to just buy it.
thanks for u fast reply, i wil repost it on your link
Like how can i downscale this ndn input from the 1080p 60fps to like something of 720p 30 fps..‍♂️
since i use to stream on facebook most of the time. Wich the max settings is for me 720p with 30fps.
Someone??
