Live Background Removal Lite
Live Background Removal Lite 4.0.1
Thank You for your work on this plug in, however, it tells me I can upgrade, but I have. I've even manually deleted it for the new one to install. I am using a Mac if that helps. I'm grateful for this notification. so please continue with it. Thanks. Update: I looked at the date and version no. of this plugin after it was installed and it is up to date. Thanks.i
Why o why doesn't 2.8.1 load into my Mac? Thank you for your efforts!
I narrowed it down to your Mac installer unfortunately. When I manually deleted it the version was like 2.5., Then I tried to install 2.8.1 It states in my plugin folder it says version 1.3.5 Created Nov. 21st
You must select to install under Users folder explicitly with installer on Monterey.
Sorry, it doesn't give me any options. It just is a universal installer. Do you have a direct link to Monterey? I think it's older than Ventura, which I have. 13.7.8.
Monterey has a severe bug about the installer system. You need to click Change Install Location... button to install OBS plugin in correct place. It won't give any option to you, but clicking Change Install Location... will fix Apple's bug. I'm working on improving the installer and soon release 3.0.0. Thanks!
umireon updated Live Background Removal Lite with a new update entry:
3.0.0 - Major version update!
Live Background Removal Lite 3.0.0: The AI Revolution for Your Stream!​
Streamers, are you ready to level up? Live Background Removal Lite 3.0.0 has arrived to revolutionize your streaming setup with cutting-edge AI magic. This isn't just an update; it's a fortress of security for your creative workflow. Say goodbye to physical green screens and hello to the future!
️ Ironclad Security for Pro Streamers​
We know...
I manually deleted the older version of your software then installed 3.0.0. It only installed one of two files hat the other one did. It didn't load the DYSM file. Should it? Mac OS Ventura. OBS 32.0.4. ....Thank you for working on it. Unfortunately an Apple bug. I changed install locations and it gave me only one like you said, so it didn't work.
3.1.1 – Documentation Improvements
We’re excited to announce Live Background Removal Lite 3.1.1!
This release focuses on making the documentation easier to read, more consistent, and more helpful for developers and users alike.
What’s improved in 3.1.1?​
Major Documentation Enhancements​
  • Improved Formatting & Clarity:
    Reworked various documentation files (including READMEs, contributing guide, and manuals) for better structure, code/example formatting, and...
I know you told me it's an apple thing, but I wanted to let you know that 3.1.1. same thing. Thank so much for trying! ...no Dysm file either.
Release 3.1.2 — Flatpak, Fedora, and Arch Build Updates
This update focuses on improvements and changes to platform packaging and build instructions, ensuring a smoother experience for users and contributors on Fedora, Arch Linux, and Flatpak-based environments.​
️ Build & Packaging Updates​
  • Flatpak & Arch Linux Packaging Moved
    • The dedicated packaging files for Flatpak and Arch Linux (PKGBUILD, manifests, update scripts) have been removed from this repository...
Good Evening. Sorry to bother.
I'm on Linux Mint using Flatpak OBS and I'm unable to install the Live Background Removal Lite with the flatpak instructions on the page.
It does built successfully, and I was able to get pretty far along, but I wasn't able to get the filter / option in OBS.
If there is any information I can provide to be helpful please let me know.
I have found a building error around OpenMP and this problem was fixed on the latest build instructions. Please try the latest one. You can remove the folder and re-clone the live-plugins-hub repository.
3.2.0
We're excited to announce the release of live-backgroundremoval-lite 3.2.0!
What's New​
  • Documentation Improvements
    The README has been updated for better clarity and to help users get started more smoothly.
  • Build System Enhancement
    The vcpkg-configuration.json has been updated, ensuring more consistent and reliable dependency management for developers building from source.
Thanks for Your Support!​
As always...
Sorry 3.2.0 still doesn't work on Mac, but installed it on Win virtual machine and it works. Unfortunately, I do every everything on my Mac and not much on my virtual. Thanks for trying!
3.3.0 - C++20
Release Notes: 3.3.0​
LiveBackgroundRemovalLite 3.3.0 is out!
This release brings major improvements to project structure, build system modularity, and asynchronous coroutine infrastructure. The refactor enhances developer experience, maintainability, and safety, paving the way for more robust and future-proof development of the plugin. Here’s what’s new and improved since 3.2.0:
Highlights​
Modernized Build...​
3.3.1 - macOS Ventura Support
Release Date: 2025-12-24
What's New in 3.3.1​
  • Ventura Support
    Live Background Removal Lite now offers improved support for Ventura (macOS 13), ensuring a smoother and more stable experience on the latest macOS platforms. This update addresses compatibility issues and enhances plugin reliability on Ventura.
️ Technical Improvements​
  • Improved Memory Alignment
    The memory alignment logic has been...
3.3.2 - Onboarding dialog
Live Background Removal Lite v3.3.2 – Friendly Release Notes​
We’re excited to announce version 3.3.2 of Live Background Removal Lite! This release focuses on improving your first experience with the plugin, making things smoother for new users, and includes some behind-the-scenes safety and resource management improvements.
What’s New & Improved​
First-Run Dialog & Onboarding​
  • Brand new "StartupUI"module: A...
