Question / Help Fps Drops in obs while i am playing/streaming fortnite
Drills
hello i started streaming and i may get some issues i got fps drops in my obs and if i cap my fps for a example on 60 my obs is good but i can reacht like 160 so is there a way to fix this?
Log file: https://obsproject.com/logs/WtjGrJcJorGlg3OP
15:58:47.246: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 4270 (21.9%)
GPU overload.
https://obsproject.com/wiki/GPU-overload-issues
15:58:47.247: Video stopped, number of skipped frames due to encoding lag: 4883/19431 (25.1%)
Encoder overload.
https://obsproject.com/wiki/General-Performance-And-Encoding-Issues
15:51:41.614: adding 42 milliseconds of audio buffering, total audio buffering is now 170 milliseconds (source: VLC Videobron)
15:51:42.372: adding 64 milliseconds of audio buffering, total audio buffering is now 234 milliseconds (source: Desktop Audio)
15:51:47.735: adding 21 milliseconds of audio buffering, total audio buffering is now 256 milliseconds (source: VLC Videobron)
Increasing audio buffering during operation is generally indicative of system overload or USB bus overload (if using multiple USB audio and/or video devices, for instance).
Fortnite is using too much of your GPU and CPU for OBS to operate; you should cap your in-game framerate and/or capture either 720p60 or 1080p30.
There's no streaming session in that log so I can't tell, but changing bitrate would not reduce rendering lag caused by GPU overload. It may be that something else you changed improved the situation, but without the output session in the log it can't be confirmed.
