Flood-Tuber | Native PNGTuber Plugin
Flood-Tuber | Native PNGTuber Plugin 1.1.0
justflood updated Flood-Tuber | Native PNGTuber Plugin with a new update entry:
FloodTuber v1.1.0
Flood Tuber v1.1.0 is Now Available!​
Hey everyone!
Version v1.1.0 of FloodTuber is live!
Changelog for v1.1.0:
  • [New Feature] Added custom avatar directory support along with a brand new UI for avatar management and detailed settings.
  • [Bug Fixes] Fixed several bugs to improve overall performance and stability.
How to Update:
If you are using an older version, I strongly...
Can you add an option to let GIF files restart from the very first frame every single time they appear? It is very frustrating to have my custom hand-drawn blinking animation start at a random point in the middle of the motion rather than starting from the beginning.
There's an even worse situation for animations that are NOT designed to loop. For example, my 'talking' animation is a GIF that acts as a smooth transition between my idle pose and my talking pose. I set the GIF to play 'ONCE' so that after showing the transition it will hold on the talking pose indefinitely until there's a break in the audio. This doesn't work, because after playing once the GIF is stuck on the final frame forever and will never ever reset.
