DroidCam OBS Camera
DroidCam OBS Camera 2.5.0
It looks like your system has FFMpeg 9.0.1, which was released on 2026-08-12 (two weeks ago).
DroidCam and OBS are still on ffmpeg 8. You could (a) downgrade ffmpeg if possible to verision 8.x, or (b) compile droidcam yourself for your system, or (c) switch to the Flatpak OBS release which has ffmpeg 8 bundled inside.
I have been using droidcam (payed version) for years on my Samsung S series. When you use Droidcam with the Samsung you can manually set the shutter speed (for example 1/60, 1/120) and ISO value which is super important to me.
Today I switched to iPhone. I bought the full version of Droidcam immediately. However, I can't find those 2 settings in droidcam. I only have the options focus, EV, white balance. Am I doing something wrong or are ISO and shutter speed not available with droidcam on iPhone? If this is true, I would have to switch back to android :(
Hey! I'm having a weird problem. I can't upgrade to a newer version with HEVC support. I tried running the installer (DroidCamOBS.Setup.2.5.1.exe), tried uninstalling and installing again, manually removing the files, opening the .exe file with 7-zip and copying the files. Everything I do ends with a plugin version without HEVC support.
In the OBS log file it always says: 11:51:26.436: [droidcam-obs] module loaded release 242 (win10.0.26200)
Phone app is Pro version on an Android phone
Hey @Sponk , this means your OBS Studio is not up to date. DroidCam v251 requires OBS 32.2.
You can also try v250 of the plugin if you would prefer not to update OBS.
Oh true, v250 works, a little bit counter intuitive, but I understand the drill. Thank you for your work and quick answer!
I'm using DroidCam/DroidCamX on a new-ish phone which has multiple lenses on the back of the phone. Is there no way to choose which of these lenses to use? Recording with the telephoto lens would be a great feature. Another app doesn't have this ability either, IP Webcam. Anyone know if there's any phone webcam app that can do this?
Update: it looks like my phone (CMF 2) in particular does not expose the auxiliary lenses to the API, that would explain it.
