Andrew_Bridgeford
I'm not really sure if the issue is with Twitch or OBS, or if this will make sense to anyone because it doesn't make sense to me. But I'm starting to think that's an OBS issue. It seemed to be sporadic but now worsened over time. For a week now when I go live to Twitch, despite that OBS and Discord says I'm live it doesn't seem to go publicly live on Twitch. Instead Twitch will show different clips of my stream that don't load and shows I'm offline and after I'm done streaming it will show my entire stream in one video in my past streams with nothing wrong with them. I submitted a ticket to Twitch support thinking it was a Twitch issue (Haven't heard back), but then I did some testing. I lowered the bitrate down and streamed, and surprise it went live properly. But that only worked for one time. When I tried to go live again it didn't work. Afterwards I tried streaming to Facebook just to test whether or not it was really a Twitch issue or something else. It did go live to Facebook, but I had the stream opened on another device and noticed that the audio seemed to repeat itself at one point in an endless loop, but everything else was fine. After I ended it, when rewatching the video Facebook saved of the stream afterwards there the wideo was perfectly fine with nothing wrong with the audio. Similar to how there are nothing wrong with any of the videos on my past streams with Twitch. So I'm confused on what the issue is. It tells me it's OBS issue but at the same time the fact that I can't go live on Twitch but I can go live on Facebook, it could possibly not be an OBS issue. I'm using OBS Studio on a Windows computer that is not really good specs but supposedly good enough for streaming considering I didn't have a problem streaming from it for months up until now. I posted all of the log files in my logs folder here (Sorry if it's too many). If anyone could help figure this out to see if it is an OBS issue and what to do about it if it is I would appreciate it.
