Crashing on startup
KampKoopa
I was trying one of the filters on my microphone I believe it was the VST option, mine works with Fruity Loops Studio so I was testing what it could do and it worked for a minute but eventually just crashed. Now OBS will not launch without crashing and if I try to open several times where it crashes the hidden icons in the taskbar fill up with OBS and FLS icons but as soon as I hover over them, they disappear. I've tried uninstalling reinstalling OBS, I've had FLS open and closed when trying to boot up OBS, I've updated my graphics cards not sure what other solutions to try. I can't interpret the crash log myself to try to fix it without help but here I am. Any help would be greatly appreciated.
  • Crash 2021-12-30 07-51-46.txt
Problem Solved: Had to ignore the crash dialog box and just go into the filter for the microphone and turn it off/disable it before OBS hard locked. Afterwords, it booted normally.
