Control Visca-over-IP based cameras
Control Visca-over-IP based cameras 2.8.1
You are welcome. I contacted Canon with a request for the Visca technical documentation. I'm curious whether they will actually share this.
You can always feel free to embarrass Canon with a comment that Panasonic provides complete documentation for their PTZ cameras ;^)
Hello, thanks for your plugin.
Could you some help.
PTZ Cam - Minrray 430E0
I need make: atrack on/track off
I don’t understand where to write this command:
81 0A 01 32 00 00 02 00 FF
Thanks for your answer.
You're welcome, thank you! :)
The dialog you are showing is the configuration of the camera. You entered code in the 'preset' list, but that's not where it goes. The preset list is to configure presets (recall a preset on the camera using a preset number). To send a command, like tracking on/off, you need to configure an action, in the source configuration for a visca action and select the action Custom Command:
In the Start command field you enter the Tracking ON command listed in the manual, but without the address 81 and the termination FF, so: 0A 01 32 00 00 02 00. To stop tracking, either fill it in as Stop command, which means tracking will be disabled when the scene is deactivated (the camera is no longer active), or in a separate scene using the same camera, but a different Visca command, where the Tracking OFF command is filled in in the Start command field.
Пожалуйста, спасибо! :)
Диалог, который вы показываете, — это конфигурация камеры. Вы ввели код в список «предустановок», но он не там. Список предустановок предназначен для настройки предустановок (вызов предустановки на камере с помощью номера предустановки). Чтобы отправить команду, например, включение/выключение отслеживания, вам нужно настроить действие в исходной конфигурации для действия visca и выбрать действие Custom Command :
В поле Start command (Команда запуска) вы вводите команду Tracking ON (ВКЛ. отслеживание) , указанную в руководстве, но без адреса 81 и окончания FF , то есть: 0A 01 32 00 00 02 00. Чтобы остановить отслеживание, либо заполните ее как Stop command (Команда остановки ), что означает, что отслеживание будет отключено, когда сцена деактивирована (камера больше не активна), либо в отдельной сцене с использованием той же камеры, но другой команды Visca, где в поле Start command (Команда запуска ) заполнена команда Tracking OFF ( ВЫКЛ. отслеживание ).
Thanks, it is in OBS input option. So, if i need always camera attive, but when i need on/off track, it mysu be different scenes with different inputs. Right?
You can do this in two ways:
- Use two scenes: One scene to enable tracking (as custom 'start' command), one scene to disable tracking (as custom 'start' command)
- Use a scene with tracking on and off as start and stop command
It depends on the rest of the scenes which is most suitable
Hi
Thank you very much for your detailed replay. Our cameras are updated to the newest available firmare (Version 1.4.0).
Thats a very good input, i will try, as soon as i have some free time to play with it, to test some different formats of the command.
As soon as i figured out someting, i will post it here.
Hi @bawunderl, I send you a private message requesting specific details. I may have found the cause for the issue (something related to different Visca protocol variants). If there is anyone else with a Canon CR-* camera that is willing to perform some test, please contact me.
I have received full Visca documentation from Canon. The specification is based on Sony C456-100-13(1) command List for BRC-X1000/H800/H78. The main difference is that an additional byte is used for the pan position. The latest code at github.com/vwout/obs-visca-control contains (untested, by lack of a camera) support.
vwout updated Control Visca-over-IP based cameras with a new update entry:
Release 2.6
This release adds better support for Canon PTZ camera's and it probably also improves this on other camera brands. The are are two command variants specified by Sony Visca protocol specifications. This script now supports both. This is expected to implement support for at least Canon CR-N300.
In case the script does not fully work with your camera, debugging became easier. Both verbose and debug logging can now be activated from the script configuration dialog; no need to modify code...
I am have been using this script for several years with great success streaming our church service. Camera position and zoom are set by a PowerPoint slide section name using the PowerPoint macro on the OBS site. I need to adjust camera settings (Canon CR-N300) based on the scene. We have both front lit scenes and back lit scenes due to large stained glass windows in the front and sides of the altar. Can you post the Canon CR-N300 Visca codes document for download? I need to change between full auto camera exposure settings, spotlight vs standard vs backlight etc. Any help would be appreciated. I am more than willing to help with testing of proposed script changes with my Canon CR-N300 setup.
The pan-tilt-zoom command with special handling for the Canon protocol variant is included in the last release(s), so available for you to test. The Canon protocol specification is attached. Let me know in case there are customizations required for other standard commands.
I would like to explain my setup current setup and my current issue which is with the camera exposure settings.
Canon CR-N300
PTZOptics Superjoy joystick (Controls the Canon PTZ functions without issue)
Atem Mini Pro
Atlona HDMI splitter
Intel i7700
32GB Ram
The PowerPoint macro from the OBS Scripts site controls the Canon CR-N300 PTZ functions and focus. The section name in the PowerPoint calls an OBS hotkey which calls the scene.
We have issues with the exposure in the scenes. We have strong front lighting for certain scenes, and strong rear lighting 2nd to large stain glass windows behind the altar and on the side walls for other scenes.
What I would like to do is to create a Visca Camera Control which would select a certain preconfigured exposure preset in the Canon exposure settings area. It is possible to create up to 63 individual presets with the Canon CR-N300.
I reviewed the Canon document you posted but I am not clear on the syntax that would be required to execute the steps.
Preset recall "8x 01 04 3F 02 pp FF" Replace FF with 01 or 02 for Prest 1, Prest 2 etc?
I had performed a test where I had OBS open on a scene, and I also had access to the Canon through IP access. I opened settings, then selected exposure, selected manual, then selected front lighting. This immediately changed the exposure to what I needed. I did not need to reboot the camera. However, when I changed to another scene, the exposure changed back to the original which was full auto exposure. When I returned back to the scene which I had changed, it reverted to original full auto exposure.
I had not tried to setup and save a preset. Reviewing the Canon manual, it appears that creating a preset involves setting PTZF settings and camera settings (color etc.). I will attempt to create a preset without PTZF settings and see if it works.
Thank you for your help.
This script is fantastic.
Correction and addition to last post:
Preset recall "01 04 3F 02 pp " Replace pp with 01 or 02 for Preset 1, Preset 2 etc? Drop 8x and FF?
Do I need a start and stop command since there is no camera movement from this script. Should this command be located before or after the separate visca camera control which moves the camera position?
Hi @UroDoc, I think you are trying to combine a few things in a way that is not intended:
- Typically camera preset as stored in the camera includes 'all' settings (what 'all' means differs from camera to camera). Storing only exposure is independent parameter is not possible with any camera I have worked with
- The Visca over IP plugin is able to recall a preset stored in the camera, not adjust parameters for it; when the plugin recalls a preset, the camera will apply all settings (see first item) associated with it
If you want to recall a preset, you can manually compose a Visca comment, but the easier way is to list the presets under the plugin settings in the Script dialog (see the documentation: https://github.com/vwout/obs-visca-control?tab=readme-ov-file#camera-settings).
If you only want to change exposure, to need to send the command that reflect the settings you want, see the respective section of the Canon instructions:
You probably need to send at least two commands:
- Send the exposure mode to manual or Shutter/Iris priority
- Set the desired parameters
Probably closing your Iris (setting the value to e.g. f/8.0) and let the camera automatically adjust shutter and gain will do the trick. In that case you will need to add two custom commands (https://github.com/vwout/obs-visca-...file#custom-command-action-execution-overview) where you only fill in the Start command:
- To set expose mode to 'Iris priority', set 'Start command' to:
01 04 39 0B
- To set the (direct) set the Iris Position, set 'Start command' to:
01 04 4B 00 00 00 05
(05 means F8.0 according documentation)
Make sure the order of the sources is to set the exposure mode first and iris priority later, so the iris priority source needs to be on top. Alternatively (or additionally) add a small delay to the Iris Priority command, to make sure it is always executed after setting the Exposure Mode.
It could be the camera automatically configures 'iris priority' when the 'Iris Position' command is set, in that case you don't need to set the exposure mode. It requires testing to find this out.
Thanks for your help. With further investigation into the Canon CR-N300, it turns out that for every scene created in OBS, a profile of all of the camera settings (position, focus, zoom, exposure, lighting etc) is created (Profile 2 etc). The profile name can then be changed to match the scene name. If you select the scene in OBS, access the camera's IP address with a browser, and select the list of profiles, you can change any camera setting for that scene and save it in the correct profile.
I am trying to enable auto tracking (Lite free version) for certain scenes and turn off for others. Since the auto tracking is an add-on Canon camera program, none of the codes to turn on or turn off the function were listed on the Canon codes you posted. Normally you are supposed to access the camera with a browser and turn tracking on or off. Is there any way with your script to open a browser, outside of obs, to access the camera and access the controls for auto tracking? Are the codes available to directly access the camera?
Thanks again for your help. Your script is phenomenal.
Update concerning auto tracking with Canon CR-N300. The built-in version works fine with OBS but is either OFF or ON for all scenes. I was unable to set auto tracking ON for only one scene. I attempted to save a profile with auto-tracking ON. But when I switched to a different scene, auto tracking remained ON (the silhouette was present). I had to go to the add-on page in the browser to turn it off. I am debating purchasing a Stream Deck to use in conjunction with an Atem Mini Pro to control auto tracking.
Any advice would be greatly appreciated.
Thanks
It might be possible to switch autotracking on and off via Visca. I can't find any related command in the Canon Visca manual, but you could try commands that work on other brands:
- Tracking ON (Crestron, PTZOptics): 01 04 3F 02 50
- Tracking ON (Aver): 01 04 7D 02
- Tracking OFF (Crestron, PTZOptics): 01 04 3F 02 51
- Tracking OFF (Aver): 01 04 7D 03
A new version of OBS came out today (32.0.0) and there is problem with the script. While it seems to be working as intended when I tested it, the script is in red text in the list of sources for all of my scenes. I don't know what that means, and I was unable to obtain any concrete information when I Googled it. This did not occur with version 32.0.
Same here - version 32 on three different new installs with OBS 32 the script does not work and I get the red text in sources. Downgrading to OBS 31 the text is no longer red, but the VISCA commands still don't fire - well, they will for the currently selected scene on startup, but that's it. Very frustrating!
If I reload the script, the VISCA command will fire once when I change a scene, but only once. Any changing to other scenes the VISCA control does not seem to fire. Reload the script and the next scene change VISCA will fire, but not on subsequent scene changes (until I reload the script and then it will fire the next scene change, but not again).
