Can't figure out why it crashes on close
I've had the same problem for years. I was on a mac with older version of OBS 27 - for a while. Then transferred to PC with version 30, and only a couple of plugins. None of which suggest an error, via analyzer. But I do have a shit ton of scenes and nested scenes and a ton more sources. I'm wondering if just having a bloated Scene collection is the issue for me. Not thinking that is your issue however, if you are new, you likely have a reasonable small scene collection. I popped your log file into OBS analyzer and it seems you do have 1 critical error. And 1 possible issue, listed as a warning. hope this helps.
Not too new! But also don't have a CRAZY amount, I do have some nested scenes however. And ya, I tried turning the accelerator off and it didn't help at all so I just put it back XD
If you have any crash logs in %APPDATA%\obs-studio\crashes folder, please, attach them here too (crash logs of OBS also can be found in main menu Help > Crash Reports > Show Crash Reports)
