Beam
Beam v1.1.0
One question for @YorVeX : I see that development of this plugin goes back to at least 2023 and you did mention the potential implementation of NVENC way back then. Are there any plans to do this? Seems like doing a 4K60 HDR capture might be a prohibitive CPU load as it stands which could hinder gaming performance, even on a high-end CPU like the 7950X3D in my gaming PC. Will give it a shot on some demanding games either way though.
Now that I've tested it out a little, it seems I'm having trouble grasping how to get this whole fixed delay thing working properly. Any tips? Also, the HDR seems washed out in my receiver as opposed to what is being sent out, and all of my P010 and Rec 2100 settings are correct on both ends. My Elgato 4K X seems to be handling the HDR just fine on the other hand.
Can't believe I just found this now. I've been searching for a dual PC HDR streaming solution that still allows me to use my DisplayPort monitor forever. Will be trying this out soon, and thank goodness for my 10Gb and 5Gb NICs on my gaming and streaming PCs respectively.
I know of 2.5 and 10 gigabit ethernet, but I've not heard of 5 gigabit ethernet. If you are going point-to-point, you might want to make sure that the 10 gigabit card can handle 5 gigabit. My Cisco Nexus is pretty old (think 2013), so it won't likely accept 2.5 or 5 gigabit devices.
That aside, I have plenty of experience of running multiple devices on the same network, pushing lots of Beam across the aforementioned Cisco Nexus.
--Katt. =^.^=
--Katt. =^.^=
My Netgear switch handles both NICs just fine.
An update to @YorVeX:
Those old ten-gigabit cards are actually PCIe Gen 1, not Gen 2, like I had originally thought. It was probably for the best to go with the Gen 3 cards I picked up for my current boxes in my streaming operations backend.
I recently picked up several Hewlett-Packard Z640 machines, three of them with dual CPUs. All of them have eight-lane PCIe slots which those cards can make full use of. I'll have to check them out at some point, but I haven't been able to cable the one I have installed just yet.
--Katt. =^.^=
So I've been using teleport for the longest time but I suffer from gaming performance loss at 90% quality on the send PC and sometimes on the receiving PC my audio gets out of sync and I can very clearly see it in the live obs log console, which i can solve by just closing and opening OBS again, does beam suffer the same problems? I'm only sending 1080p60 and about 4 audio tracks
I have a x570 Aorus, 5800x, 3080 10gb, 32gb ram and my receiving end is a laptop lenovo slim 7 gen 6 with 5800H laptop 3060(80-100w), teleport works but its just annoying to restart my obs every now and then to fix teleport getting out of sync and its annoying to lose about 5-10% of my gaming performance just because teleport is active.
Depends on the root cause of the problem. If that receiving laptop is on Wifi, Beam won't improve the situation, using a wired Ethernet connection for the laptop will. People often overestimate the performance of their Wifi, because the marketing for the Wifi router says 1200 or even 2400 mbps, which sounds plenty, but in reality on a typical unoptimized network you get 100-200 on average with occasional dips down to 10.
If it already is on Ethernet and you still have the desync issues, Beam might actually help when activating the frame buffer feature, because that can counter desyncs.
I am using a full ethernet setup over 1gbps switch. I will try out beam now thank you! how about video/audio delay? I know teleport has a roughly 270ms delay, and you didnt answer my question about gaming performance loss on the Send PC. I observed this behavior from teleport, on the game(send) PC i lose about 5-10% of performance which is annoying sometimes.
1G unfortunately means you need a lot of compression to get 1080p60 through there, and that means using the same JPEG compression Teleport is using and losing performance on the sender PC because of the compression work done on the CPU. And the delay also won't improve, in fact if you use the frame buffer feature, that will intentionally add more delay.
There is still 3 reasons why Beam could be useful in your scenario:
  1. More general stability against desyncs. Though to be honest, my last comparison tests with Teleport were a while ago. All I can say is that I spent lots of team to optimize especially that aspect on OBS. A 100% fix isn't possible though, as OBS simply wasn't meant to have plugins do remote transmissions like that, so every plugin will always suffer a bit from that.
  2. Frame buffer based extra stability against desyncs. You need to enable the frame buffer for that. Some desyncs occur because of fluctuations in delay, which can't be fully avoided in OBS, but Beam counters it by adding an artificial delay where it buffers frames, and then it uses this buffer to counter OBS delay changes, e.g. if OBS delay increases by 200 ms, Beam automatically reduces its buffer by 200 ms so that you end up with the same final delay. Also this buffer is used to stabilize temporary gaps in transmission.
  3. Reduce compression load by not compressing all frames. In Beam, for JPEG you not only have the JPEG compression quality option (which is the same as the Teleport quality setting and you should leave at 90), but also the JPEG compression level. If you lower this, some frames are left uncompressed, saving compression work on these frames at the expense of increasing bandwidth usage. Try to lower it step by step, start at 9, and see what your network can handle. You should see a performance improvement on the sender side with every step. If you lower it too much and overload your network, you will get lags and issues, make sure to leave enough headroom.
Some longer time ago when I tested, Beam also had slightly lower base CPU usage than Teleport even when both were using JPEG, but I am not listing that as point 4 since I think I've seen a Teleport update with some optimizations since then, I'd have to rerun the tests to see whether this is still true. Maybe you can report here on your findings.
